| Message |
When the truck company loaded your car, they probably slipped the clutch with a bit of RPM the whole way up the ramp. They probably needed to do this to slowly load the car up a steep ramp. Because your running feramic material, the material became hot enough to melt, this caused the disc to weld itself to the flywheel. When feramic material melts, it attaches itself to other clutch surfaces, it can be broken loose, the issue is it leaves part of the material attached to the other surface, the part that stays attached causes a high spot that will not allow the disc to fully release. More than likely, the only way your clutch will release again is if you take it all apart and remove the high spots. If you continue to use the feramic disc, make sure you do not slip it much, and do not use it for drag racing.
